Salta al contenuto principale
How to fix Logitech M171 Mouse Laser
  1. How to fix Logitech M171 Mouse Laser, Remove the plastic cover: passo 1, immagine 1 di 1
    • Remove the plastic cover at the bottom of the mouse
  2. How to fix Logitech M171 Mouse Laser, Remove the battery and wireless key: passo 2, immagine 1 di 1
    • Remove the battery and wireless key
  3. How to fix Logitech M171 Mouse Laser, Removing the front cover: passo 3, immagine 1 di 2 How to fix Logitech M171 Mouse Laser, Removing the front cover: passo 3, immagine 2 di 2
    • Remove the front cover as show
  4. How to fix Logitech M171 Mouse Laser, Removing the sensor: passo 4, immagine 1 di 1
    • Pull on the sensor to remove it
  5. How to fix Logitech M171 Mouse Laser, Clean the sensor: passo 5, immagine 1 di 2 How to fix Logitech M171 Mouse Laser, Clean the sensor: passo 5, immagine 2 di 2
    • Clean the sensor with an tissue soaked in alcohol
  6. How to fix Logitech M171 Mouse Laser, Reassembly insert sensor: passo 6, immagine 1 di 2 How to fix Logitech M171 Mouse Laser, Reassembly insert sensor: passo 6, immagine 2 di 2
    • Insert sensor as shown
  7. How to fix Logitech M171 Mouse Laser: passo 7, immagine 1 di 2 How to fix Logitech M171 Mouse Laser: passo 7, immagine 2 di 2
    • Install the front plate put the front plate down on the mouse and push Down until it clips in
    • Install battery and USB key and back cover and you’re done
Conclusione
You’re done Thanks for completing the guide
Altre 2 persone hanno completato questa guida.
Maimlian
Membro da: 01/27/22
504 Reputazione
2 Guide realizzate
3Commenti sulla guida
Frying the darker plastic cover open without damaging it is near impossible. I have a problem with my mouse wheel and I don't know how to lubricate it or fix the sensor. Can someone help with that?
Efe Şimşek - Replica
These are bad instructions, the top is released with 3 clips accessible under the battery cover, prising it off from above will break those clips. It can be hard to work out where the clips are and how to release them, but there are 3 one on each side and on under the battery. Aside from that the only other retention is a couple of hooks on the mouse buttons.
Gordon Wrigley - Replica
Agree that prizing the top off like this is going to damage it! Maybe my mouse, being blue on top, and black on bottom made this easier to spot, but it was very easy for me to see the three clips on the bottom. Hopefully anyone who wants to open theirs will see your comment and not use the opening tool like this.
Sid R -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 115
Tutti i Tempi: 6,058
