Salta al contenuto principale
Introduzione
After a couple of thousands clicks the Anywhere MX Mouse develops a phantom double click. This is due to a grove that develops on the inside of the button. It can be fixed with a piece of tape.
  1. The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
    • The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
  2. The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
    • The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
  3. Skip the upgrade.
    Ottieni $10 di sconto su $50 con
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
  4. After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
    • After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
  5. Put a piece of tape over the groove.
    • Put a piece of tape over the groove.
    This is made a TOTAL difference in my mouse….THANKS!
    K Denny - Replica
    Thanks for this information, it resolves the issue. I did not add the piece of tape, but instead filed the plastic so the groove was gone. There is enough play in the button to accommodate the additional motion needed to activate the switch and there is no chance the tape will come off in the future. Should be good for another 100k miles, though your mileage may vary…:)
    jaypug06791 - Replica
    This is awesome..I was able to fix my MX mouse. Thanks
    Ravindran
    Ravindran Keshavan - Replica
Conclusione
Altre 29 persone hanno completato questa guida.
Worked well for me, lets see how long it'll last.
Wynadorn - Replica
Worked for me too...saved a great little mouse!
jcrhino - Replica
Thank you for this hint! It worked perfectly
Wojciech Gradkowski - Replica
Thank you, it worked!
Jakab Ponoczky - Replica
Thank you for this guide! Got my mouse working and saved me some money :)
Kon-Kon Chao - Replica
second time for me. So thanks twice !
I cut a couple of tiny pieces of stainless shim and glued them in place of the tape. I cut these from the internals of a failed inkjet printer to prolong the life of the repair.
effgee - Replica
Very helpful, thanks!
kalrnux - Replica
Worked like a charm… Hope it lasts a few more years, the mouse is great.
Ariel Masciotta - Replica
Had to put three layers of tape on it, but now it works as great as all the years before. Thank you very much!
Baghira - Replica
Put two layers of tape on mine - this tip worked like a charm! very grateful for the advice - glad I don’t have to buy a brand new $80 mouse now!
heath whaley - Replica
Thank you for this!! It worked very well! The mouse is great, it’s a shame it comes with this glitch though…
Ronaldo Jr - Replica
your solution is great; however i did not need to dismantle the mouse to apply the fix. i simply and delicately pulled the mouse button up and out of its socket. after bracing the button by wedging a pencil between the mouse body and button i applied three small electrical tape pieces to the button groove. finally i pressed the button back into its socket.
Axiom Aziz - Replica
Wow, amazingly simple solution for the problem. It really works. I was thinking in buy a new one, but now is not necessary. Thanks a lot!
Jorge Anais - Replica
Worked out just fine. Thanks for a great tear-down and solution!! I wouldn’t have figured it out . . . ever!
Michael Lutynski - Replica
Worked perfectly, simple fix that saved me replacing the mouse.
John Fletcher - Replica
Giving it a shot, thanks for this - double click has been driving me bonkers.
Ryan Reinike - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 112
Ultimi 30 Giorni: 454
Tutti i Tempi: 12,039
