Salta al contenuto principale
How to fix Logitech Anywhere MX Phantom Double Click
Cosa ti serve
  1. How to fix Logitech Anywhere MX Phantom Double Click, Front Screw Removal: passo 1, immagine 1 di 1
    • The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
  2. How to fix Logitech Anywhere MX Phantom Double Click, Removing Back Screws: passo 2, immagine 1 di 1
    • The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
  3. How to fix Logitech Anywhere MX Phantom Double Click, Identification of the Problem: passo 3, immagine 1 di 1
    • After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
  4. How to fix Logitech Anywhere MX Phantom Double Click, Solution of the Problem: passo 4, immagine 1 di 1
    • Put a piece of tape over the groove.
Conclusione
Altre 63 persone hanno completato questa guida.
43Commenti sulla guida
Worked well for me, lets see how long it'll last.
Wynadorn - Rispondi Condividi
Worked for me too...saved a great little mouse!
jcrhino - Rispondi Condividi
Thank you for this hint! It worked perfectly
Wojciech Gradkowski - Rispondi Condividi
Thank you, it worked!
Jakab Ponoczky - Rispondi Condividi
Thank you for this guide! Got my mouse working and saved me some money :)
Kon-Kon Chao - Rispondi Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 165
Tutti i Tempi: 51,669
