Salta al contenuto principale
How to easily fix a Xbox 360 drive that wont open.
Cosa ti serve
  1. How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: passo 1, immagine 1 di 2 How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: passo 1, immagine 2 di 2
    • First we need to take off the face plate.
  2. How to easily fix a Xbox 360 drive that wont open.: passo 2, immagine 1 di 1
    • Use a paper clip or a long pick tool to manually open DVD Drive.
  3. How to easily fix a Xbox 360 drive that wont open.: passo 3, immagine 1 di 2 How to easily fix a Xbox 360 drive that wont open.: passo 3, immagine 2 di 2
    • Use tweezers to take a rubber belt of 2 pulleys in between the hole in the DVD Tray.
  4. How to easily fix a Xbox 360 drive that wont open.: passo 4, immagine 1 di 2 How to easily fix a Xbox 360 drive that wont open.: passo 4, immagine 2 di 2
    • Use a damp paper towel to thoroughly clean the rubber belt.
  5. How to easily fix a Xbox 360 drive that wont open.: passo 5, immagine 1 di 1
    • Use the tweezers to put the rubber belt back on the 2 pulleys we took them off of.
    • I have found it is easier to start with the big pulley first then once around the big pulley get the belt around the small belt.
  6. How to easily fix a Xbox 360 drive that wont open.: passo 6, immagine 1 di 2 How to easily fix a Xbox 360 drive that wont open.: passo 6, immagine 2 di 2
    • Close the DVD Drive and put the face plate back on.
    • Plug the system in and test to see if the drive works.
Conclusione
These steps have helped me fix 2 original Xbox systems and 3 Xbox 360 systems. I hope it helps yall. If you need any clarification on any of the steps please message me.
Altre 15 persone hanno completato questa guida.
Matt Weatherly
Membro da: 09/16/12
1.203 Reputazione
2 Guide realizzate
8 Commenti
the picture of the exbox is not mine
dongwillows - Replica
the picture you show is not my console
My xbox 360 console looks like this but does not have a hole to manually open the tray.
Don - Replica
It had to use different tools to open and clean the rubber pulley with 70% Alcohol. Thank you for posting it i fixed my 2009 Black xbox 360 Console.
Gustavo Montes - Replica
How did you open your Xbox? Because mine also doesn’t have that hole
Astr0 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 18
Ultimi 7 Giorni: 94
Ultimi 30 Giorni: 251
Tutti i Tempi: 9,691
