Salta al contenuto principale
How to downgrade Jadoo2
  1. How to downgrade Jadoo2, Turn off Jadoo2: passo 1, immagine 1 di 2 How to downgrade Jadoo2, Turn off Jadoo2: passo 1, immagine 2 di 2
    • Press the Power switch on the back of the Jadoo2, or press the power button on the remote to turn it off.
  2. How to downgrade Jadoo2, Starting the process: passo 2, immagine 1 di 1
    • To begin, press the power button on your remote, or press the switch on the back to turn on the Jadoo2
    • While turning the Jadoo2 on, Press & Hold the OK button on your remote for 10 seconds.
    • You should see a Menu with some options such as doing a Factory reset and many more.
    • On the menu you should see an option that says “Run the previous software”
    • Click the corresponding button for “Run the previous software”
    • Once it is done booting up. Everything should be like the old software.
Conclusione
Unless the software asks if you want to update the software, there is no return.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 53
