Salta al contenuto principale
How to disassemble a Bowers & Wilkins Zeppelin
Cosa ti serve
  1. How to disassemble a Bowers & Wilkins Zeppelin, Remove iPod holder (not a must but can be helpful): passo 1, immagine 1 di 3 How to disassemble a Bowers & Wilkins Zeppelin, Remove iPod holder (not a must but can be helpful): passo 1, immagine 2 di 3 How to disassemble a Bowers & Wilkins Zeppelin, Remove iPod holder (not a must but can be helpful): passo 1, immagine 3 di 3
    • Put the unit on its side and then remove the rubber plate from the bottom.
    • then unscrew the four screws (tamper-resistant Torx, but a small screwdriver is enough here).
  2. How to disassemble a Bowers & Wilkins Zeppelin, Remove iPod holder: passo 2, immagine 1 di 1
    • Carefully remove the ribbon (press the clamp still in front) and lay the docking arm to one side.
  3. How to disassemble a Bowers & Wilkins Zeppelin, Remove speaker grilles: passo 3, immagine 1 di 2 How to disassemble a Bowers & Wilkins Zeppelin, Remove speaker grilles: passo 3, immagine 2 di 2
    • Use a flat plastic tool or a blunt knife in the slot between the chrome bar and speaker cover to push the grille outward, while at the same time pressing the plastic fastener on the back side at the edge. USE CAUTION, the clips can break easily. Then slide the cover slowly to the side.
  4. How to disassemble a Bowers & Wilkins Zeppelin, Remove screws holding unit together: passo 4, immagine 1 di 2 How to disassemble a Bowers & Wilkins Zeppelin, Remove screws holding unit together: passo 4, immagine 2 di 2
    • Remove the 8 philips screws from the front of the unit.
    • The remove the 2 smaller philips screws from the rear of the unit behind the tweeters.
  5. How to disassemble a Bowers & Wilkins Zeppelin, Open the Zeppelin: passo 5, immagine 1 di 2 How to disassemble a Bowers & Wilkins Zeppelin, Open the Zeppelin: passo 5, immagine 2 di 2
    • Carefully pull the housing towards you to split the unit apart.
    • Loosen and remove the 3 cables (shown with the RED arrows in the picture)
    • Remove the screws from the power supply (4 pieces shown with the GREEN arrows) and remove the power supply.
    • Remove the screws holding the heat-conducting sheet (5 pieces shown with the YELLOW arrow).
    • solder the new 250V T1.6A fuse to the board
  6. How to disassemble a Bowers & Wilkins Zeppelin: passo 6, immagine 1 di 1
    • Having checked the fuse and the capacitors, I found on my two power supplies (I bought a second broken one for spare parts) that this resistor had blown or at least was without a jacket.
    • As such I couldn't determine the value, and as it is buried so deep in the board, I stopped the repair here.
Conclusione
Altre 17 persone hanno completato questa guida.
24 Commenti
Mein Zeppelin schaltet sich nicht ein (die LED bleibt aus).
Also dachte ich auch, dass die Sicherung oder etwas anderes am Netzteil defekt ist. Ich habe den Zeppelin wie in dieser sehr hilfreichen Anleitung geöffnet, aber die Sicherung ist ok.
Wenn ich mit dem Multimeter die Spannung am Netzteil Ausgang messe ist diese aber 0V (zwischen allen Pins).
Bedeutet das, dass das Netzteil kaputt ist?
Falls ja, an welcher Komponente liegt das am ehesten?
tobias - Replica
schon das untere Blech abgenommen und mal von unten geschaut ob eventuell ein Kondensator explodiert ist?
lalbert3 - Replica
Auf dem Netzteil sollte doch auch Spannung sein, wenn ich es ausgebaut habe und an die Steckdose anschließe? Es muss nicht an den Rest angeschlossen sein?
tobias -
Jap, keiner von außen sichtbar beschädigt, einige Lötstellen sind deutlich braun verfärbt.
tobias - Replica
Mein Sohnemann (1.5-jährig) hat auf der Rückseite des Zeppelins einen Schlüssel in den Lautsprecher hineingesteckt, den ich nun nicht mehr raus bekomme. Kann ich zu dem Schlüssel gelangen, wenn ich das Ding gemäss dieser Anleitung aufschraube oder ist es aussichtslos?
Der Zeppelin funktioniert immer noch einwandfrei.
Simone - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 312
Tutti i Tempi: 44,318
