Introduzione
This guide will tell you how to prevent somebody to steel your money and/or identity when your credit or debit card expired or is replaced.
Note this can NOT be undone
  1. Take a magnet and swipe it over the magnetic strip minimum 10 times.
    • Take a magnet and swipe it over the magnetic strip minimum 10 times.
    • Take something sharp and make hole where the chip was.
    Aggiungi Commento
  2. Use a pair of scissors and cut the card into thin strips.
    • Use a pair of scissors and cut the card into thin strips.
    • See the photo.
    • It is not recommended to have the strips thicker then 2mm.
    Saving and collecting the little gold emblem could make you some money in the future.
    Clifton Linne - Replica
  3. Diffondi allegria Fixmas
    Ottieni $12 sul tuo acquisto di $50 o più con il codice FIXMAS12
    • The distance you see in the blue circle is not recommended to be more then 2mm.
    • Cut the card into many small parts as seen on the photo.
    • It is recommended to have a box/tin to prevent the parts to fly anywhere.
    Aggiungi Commento
    • Look on the floor and on the table and see if you lost some parts of the card
    • If you found some, cut them also.
    • See previous steps.
    Aggiungi Commento
    • Take some parts in the trash at home and some other an other place, eg work, public area, etc.
    • Recomanded min 2 places
      • Taking it to the neighbor will not increase security a lot.
    Aggiungi Commento
Linea Traguardo
Altre 24 persone hanno completato questa guida.
You didn't mention how to destroy the chip. You need to destroy the chip also. Otherwise this method is very good (excellent if it wasn't a chip card.)
thealy449 - Replica
Would've been easier to burnt the CC to ashes . Now that's one and only one way that you will keep it from falling in to the anyone's scam, fraud...
Hiram Pabon - Replica
Please correct some typo but yes you got the
Now for anything that has 2 do w/a/pc's smartphone has a has a has a.
Rabitts take the hard drive and burnt it to a crispy ashes.
Fire destroyed anything
Destroys anything
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 117
Tutti i Tempi: 9,266
