Introduzione
Metals used in circuits can react with oxygen. It's a common and natural reaction and can cause connection problems, but the process is reversible with deoxidizing sprays which can improve the sound quality of your amplifier.
Cosa ti serve
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
Carefully wipe the circuit board and its components to remove any dust.
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
As an electronic repair technician I would never advise spraying deoxit on a circuit board or removing dust with a papertowel. May I suggest using a can of compressed air to remove any dust inside the unit and focusing the use of contact cleaner on potentiometers, input/output jacks, sockets/plugs etc. Cleaning the top of the circuit board will do little to nothing to improve the performance or sound of your amplifier as you will simply be cleaning the top side of components that are physically soldered to pads on the other side of the PCB.
A soft long bristle brush
