Salta al contenuto principale
How to clone a Hard Drive or a Solid State Drive on a Mac
Cosa ti serve
  1. How to clone a Hard Drive or a Solid State Drive on a Mac, Downloading Carbon Copy Cloner: passo 1, immagine 1 di 1
    • Download Carbon Copy Cloner from the Bombich Software Website.
    • Install it onto your macOS based computer. You will need administrator privileges later, as well as to move CCC into the Applications folder on your computer.
    • You can download it here.
    • I used CCC 5 for this process and if the user interface changes in the future I will promptly update the guide.
  2. How to clone a Hard Drive or a Solid State Drive on a Mac, Preparing for Cloning - Source Disk: passo 2, immagine 1 di 1
    • Once you are at the main screen of Carbon Copy Cloner, insert your SATA based SSD/SSHD/HDD into your enclosure and plug it into your Mac.
    • Under Source Disk, click your current HD/SSD. For example, my current drive is named "Macintosh SSD".
  3. How to clone a Hard Drive or a Solid State Drive on a Mac, Preparing for Cloning - Target Disk: passo 3, immagine 1 di 1
    • Next, select your Target Disk. My target disk is named "Ubuntu". Your disk can have any type of name ex. "Pie".
  4. How to clone a Hard Drive or a Solid State Drive on a Mac, Cloning: passo 4, immagine 1 di 1
    • Lastly, click Clone.
    • Enter your administrator Username
    • Enter your administrator Password
    • Then finally, click OK
    • This process can take up to 4+ hours depending on your disk size, so have some patience!
Conclusione
After you finish, install your new Hard Drive/Solid State Drive and test if it works. If it does not, try cloning again. If it still does not work after that, leave a comment and I will try my best to support you.
Altre 21 persone hanno completato questa guida.
[deleted]
Membro da: 08/28/18
24.860 Reputazione
21 Guide realizzate
8 Commenti
I have used CCC for years and years. It is an excellent program!
When upgrading MAC OS to a new version, I always clone a drive before starting the upgrade.
Mal - Replica
What if you have several volumes on each disk ? Does it scan the entire structure and boot options ?
Fran Werttt - Replica
CCC clones per volume, not per disk. So you have to clone each volume on their own, how many are bootable?
Jelan -
I have tried cloning my 2012 Mac book pro with a vector ssd sata111, my Mac does not see the disk when I connect with usb or caddy, this is getting frustrating anyone has the same problem where you mac not seeing the ssd drive
thank you
Peter
Peter - Replica
What about using Restore on Disk Utility read on web that this in itself a cloning method don’t have to go for 3rd party apps
GBish - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 30
Ultimi 7 Giorni: 141
Ultimi 30 Giorni: 555
Tutti i Tempi: 14,792
