Salta al contenuto principale
How to clear a Epson Stylus Photo 820 paper jam
  1. How to clear a Epson Stylus Photo 820 paper jam, How to clear a Epson Stylus Photo 820 paper jam: passo 1, immagine 1 di 2 How to clear a Epson Stylus Photo 820 paper jam, How to clear a Epson Stylus Photo 820 paper jam: passo 1, immagine 2 di 2
    • If a paper jam is detected, the middle button will display a red light.
    • Press the red button. This will cause the printer to try to automatically correct the issue.
    • If this works, proceed to step 4. Otherwise, proceed to step 2.
  2. How to clear a Epson Stylus Photo 820 paper jam: passo 2, immagine 1 di 2 How to clear a Epson Stylus Photo 820 paper jam: passo 2, immagine 2 di 2
    • The first step in repair is to attempt to remove the paper jam by pulling it out through the top.
    • Pull the paper slowly, and as straight as possible.
    • If this does not work, proceed to step 3.
  3. How to clear a Epson Stylus Photo 820 paper jam: passo 3, immagine 1 di 2 How to clear a Epson Stylus Photo 820 paper jam: passo 3, immagine 2 di 2
    • Assuming the paper will not come out of the top, assess the paper jam.
    • If the print cartridge is in the way, gently push it to the side.
    • Try to get the full edge of the paper above the metal grating.
    • Gently pull the paper out the of the open hatch.
  4. How to clear a Epson Stylus Photo 820 paper jam: passo 4, immagine 1 di 2 How to clear a Epson Stylus Photo 820 paper jam: passo 4, immagine 2 di 2
    • If the paper jam was corrected during step 1, the red light should have turned off, leaving only a green light.
    • If steps 2 or 3 corrected the problem, you will need to press the red button again.
    • This may cause another sheet of paper to be pulled through. Do not be alarmed.
    • This should cause the red light to go out.
Linea Traguardo
Cal Poly, Team 20-68, Walters Spring 2011 Membro di Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,260
