Introduzione
This guide can teach you how to repair/remove a paper jam for the Epson Stylus Photo 820. No tools are necessary for this operation, and no working knowledge of the printer is needed.
If a paper jam is detected, the middle button will display a red light.
Press the red button. This will cause the printer to try to automatically correct the issue.
If this works, proceed to step 4. Otherwise, proceed to step 2.
If the paper jam was corrected during step 1, the red light should have turned off, leaving only a green light.
If steps 2 or 3 corrected the problem, you will need to press the red button again.
This may cause another sheet of paper to be pulled through. Do not be alarmed.
This should cause the red light to go out.
