Salta al contenuto principale
How to clear a Canon PIXMA MP190 paper jam
Guida Archiviata
Questa guida รจ mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
  1. How to clear a Canon PIXMA MP190 paper jam, Locate Paper Jam: passo 1, immagine 1 di 2 How to clear a Canon PIXMA MP190 paper jam, Locate Paper Jam: passo 1, immagine 2 di 2
    • For safety ensure that the printer is powered off.
    • Lift the scanning unit until the scanning until support is vertical.
    • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  2. How to clear a Canon PIXMA MP190 paper jam, Step 2: passo 2, immagine 1 di 2 How to clear a Canon PIXMA MP190 paper jam, Step 2: passo 2, immagine 2 di 2
    • Locate the paper jam.
    • Firmly grasp the end of the paper that is most accessible.
    • Pull the jammed piece of paper from the printer evenly.
  3. How to clear a Canon PIXMA MP190 paper jam, Inspect Printer: passo 3, immagine 1 di 1
    • Inspect the printer thoroughly to ensure that all pieces of paper have been removed.
  4. How to clear a Canon PIXMA MP190 paper jam, Clean Paper Feed Rollers: passo 4, immagine 1 di 1
    • Scrub the paper feed roller using the detailing brush.
    • The roller can be rotated manually so the entire surface of the roller can be cleaned.
  5. How to clear a Canon PIXMA MP190 paper jam, Restore Functionality: passo 5, immagine 1 di 2 How to clear a Canon PIXMA MP190 paper jam, Restore Functionality: passo 5, immagine 2 di 2
    • Lift up the scanning unit and press the scanning unit support inward while lowering the scanning unit.
    • The printer is now ready to print.
Conclusione
Altre 2 persone hanno completato questa guida.
Michigan Tech, Team 1-5, Lauer Fall 2014 Membro di Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,206
