Salta al contenuto principale
How to clear Lexmark Intuition S505 paper jam
  1. How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: passo 1, immagine 1 di 2 How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: passo 1, immagine 2 di 2
    • Lift the scanning unit.
  2. How to clear Lexmark Intuition S505 paper jam: passo 2, immagine 1 di 2 How to clear Lexmark Intuition S505 paper jam: passo 2, immagine 2 di 2
    • Check the duplex unit, located at the rear of the printer, for any paper obstruction. Pinch the top button to remove the unit.
  3. How to clear Lexmark Intuition S505 paper jam: passo 3, immagine 1 di 1
    • If there is any paper stuck inside, remove it. If not, snap the unit back onto the printer.
  4. How to clear Lexmark Intuition S505 paper jam: passo 4, immagine 1 di 1
    • Check the front slot, which is located underneath the LED display. If there is any paper, remove it.
Conclusione
Once the paper obstruction is removed, your printer should print smoothly without any problems.
Altre 2 persone hanno completato questa guida.
Omar
Membro da: 01/23/13
111 Reputazione
2 Guide realizzate
Cal Poly, Team 18-38, Regan Winter 2013 Membro di Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Membri
8 Guide realizzate
Un commento
Mine still says paper jam but there's no paper stuck in it all. Can you suggest other probs and solutions?
Debra Collis (Debbie) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,639
