Salta al contenuto principale
How to clean/replace buttons on the Skytex SP728
Cosa ti serve
  1. How to clean/replace buttons on the Skytex SP728, Case: passo 1, immagine 1 di 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. How to clean/replace buttons on the Skytex SP728: passo 2, immagine 1 di 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. How to clean/replace buttons on the Skytex SP728: passo 3, immagine 1 di 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. How to clean/replace buttons on the Skytex SP728: passo 4, immagine 1 di 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. How to clean/replace buttons on the Skytex SP728, How to clean/replace buttons on the Skytex SP728: passo 5, immagine 1 di 1
    • Remove the black buttons (they should not be directly attached to the device and may fall out).
  6. How to clean/replace buttons on the Skytex SP728: passo 6, immagine 1 di 1
    • On side the circuit board there will be three buttons. One is the power button, and the other two are volume buttons.
Conclusione
Chris Nelson
Membro da: 01/21/15
213 Reputazione
2 Guide realizzate
USF Tampa, Team 5-1, Brown Winter 2015 Membro di USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 143
