Introduzione
This guide will walk you through the steps to cleaning the Roomba air filter. A clean filter will improve performance and should be checked regularly.
Parti
Nessuna parte richiesta.
  1. Slide out back bin by pressing the unmarked button on top of the Roomba.
    • Slide out back bin by pressing the unmarked button on top of the Roomba.
  2. Slide out yellow bar on particle bin to access filter
    • Slide out yellow bar on particle bin to access filter
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. This is the air filter assembly
    • This is the air filter assembly
  5. Pop out filter mount by prying 2 points that hold it to the rest of the assembly
    • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
  6. Thoroughly clean or replace the air filter.  This can be done with compressed air or by rinsing it with water.
    • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
  7. Reassemble the air filter assembly and slide the particle bin back into place
    • Reassemble the air filter assembly and slide the particle bin back into place
Conclusione
Altre 3 persone hanno completato questa guida.
Scott Leonard
Membro da: 05/10/2010
439 Reputazione
3 Guide realizzate
Cal Poly, Team 20-6, Maness Fall 2010 Membro di Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
2 Membri
3 Guide realizzate
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - Replica
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 4,703
