Salta al contenuto principale
How to clean the Sega Genesis game port
Cosa ti serve
  1. How to clean the Sega Genesis game port, How to clean the Sega Genesis game port: passo 1, immagine 1 di 1
    • Fold fine grit sand paper over a credit card.
  2. How to clean the Sega Genesis game port: passo 2, immagine 1 di 1
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
  3. How to clean the Sega Genesis game port: passo 3, immagine 1 di 1
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
  4. How to clean the Sega Genesis game port: passo 4, immagine 1 di 1
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
Linea Traguardo
Altre 12 persone hanno completato questa guida.
Cal Poly, Team 3-29, Regan Fall 2010 Membro di Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Membri
14 Guide realizzate
5Commenti sulla guida
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - Replica
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - Replica
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - Replica
Worked great for my Sega Genesis Model 2 console (which was super flaky before). Also cleaned my cartridge contacts with rubbing alcohol on cotton swabs, made a HUGE difference. Thank you for this.
fcjohnson65 - Replica
I tried alcohol and toothbrush, q-tips, and looked over the board for circuit problems. I was still getting a black screen for every game i tried. But this worked perfectly. I'm shocked. My contacts were already shiny clean but they needed light sandpaper apparently.
colinplank - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 102
Tutti i Tempi: 38,488
