Salta al contenuto principale
How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45
Cosa ti serve
  1. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, Battery: passo 1, immagine 1 di 2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, Battery: passo 1, immagine 2 di 2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 2, immagine 1 di 1
    • Use a plastic opening tool to pry the back panel off.
  3. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 3, immagine 1 di 2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 3, immagine 2 di 2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 4, immagine 1 di 2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 4, immagine 2 di 2
    • Remove the ribbon cable with a pair of tweezers.
  5. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 5, immagine 1 di 1
    • Lift and remove the battery.
  6. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, Fan: passo 6, immagine 1 di 1
    • Gently peel off the tape from the fan.
  7. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 7, immagine 1 di 2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 7, immagine 2 di 2
    • Remove five 5mm screws using a Phillips 0 screwdriver.
    • Remove the two 2mm screws with a Phillips 000 screwdriver.
  8. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 8, immagine 1 di 1
    • Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
  9. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 9, immagine 1 di 2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 9, immagine 2 di 2
    • Grab the sides of the fan assembly and remove it by lifting upwards.
  10. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 10, immagine 1 di 1
    • Remove the tape connected to the fan covering plate.
  11. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 11, immagine 1 di 1
    • Gently pull the covering plate from the covering tab.
  12. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 12, immagine 1 di 1
    • Remove the covering plate.
  13. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 13, immagine 1 di 2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: passo 13, immagine 2 di 2
    • From the back, push the fan out of the motor.
    • Clean the fan using a damp cloth, and allow to dry.
Conclusione
Bryann Tan
Membro da: 09/25/16
877 Reputazione
6 Guide realizzate
USF Tampa, Team 16-2, Eyestone Fall 2016 Membro di USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,341
