Salta al contenuto principale
How to clean the CONDOR L130I3E fan
Panoramica Video
  1. How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: passo 1, immagine 1 di 3 How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: passo 1, immagine 2 di 3 How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: passo 1, immagine 3 di 3
    • First of all, make sure your device is switched off and unplugged.
    • Remove the battery by pulling the two screws in the direction indicated by the pins.
    • Pull the battery up.
  2. How to clean the CONDOR L130I3E fan: passo 2, immagine 1 di 3 How to clean the CONDOR L130I3E fan: passo 2, immagine 2 di 3 How to clean the CONDOR L130I3E fan: passo 2, immagine 3 di 3
    • To remove the hard drive, unplug its screws in this cover.
    • Pull the hard drive in the direction indicated to remove it.
    • Then we remove the hard drive from its place with ease.
  3. How to clean the CONDOR L130I3E fan: passo 3, immagine 1 di 3 How to clean the CONDOR L130I3E fan: passo 3, immagine 2 di 3 How to clean the CONDOR L130I3E fan: passo 3, immagine 3 di 3
    • To access the motherboard, you must first remove the keyboard because underneath it screws should be removed to separate the base of the chassis from the top of the keyboard.
    • With a flat screwdriver we remove the keyboard by pressing the red-pointed component and pushing the keyboard up to release it.
  4. How to clean the CONDOR L130I3E fan: passo 4, immagine 1 di 2 How to clean the CONDOR L130I3E fan: passo 4, immagine 2 di 2
    • Remove the keyboard connector from the motherboard
    • Keyboard is now removed successfully
  5. How to clean the CONDOR L130I3E fan: passo 5, immagine 1 di 3 How to clean the CONDOR L130I3E fan: passo 5, immagine 2 di 3 How to clean the CONDOR L130I3E fan: passo 5, immagine 3 di 3
    • Remove the top cover and remove the processor cooling fan.
    • Unscrew the screws indicated in red to remove the cooling fan.
    • Remove the fan.
  6. How to clean the CONDOR L130I3E fan: passo 6, immagine 1 di 1
    • We now clean and remove the dust and sediments that hinder fan function and increase processor heat.
Conclusione
Altre 7 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,195
