Salta al contenuto principale
How to clean the Brother HL-5240 corona wire
  1. How to clean the Brother HL-5240 corona wire, Drum Unit and Toner Cartridge: passo 1, immagine 1 di 1
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. How to clean the Brother HL-5240 corona wire: passo 2, immagine 1 di 3 How to clean the Brother HL-5240 corona wire: passo 2, immagine 2 di 3 How to clean the Brother HL-5240 corona wire: passo 2, immagine 3 di 3
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
  3. How to clean the Brother HL-5240 corona wire, How to clean the Brother HL-5240 corona wire: passo 3, immagine 1 di 3 How to clean the Brother HL-5240 corona wire, How to clean the Brother HL-5240 corona wire: passo 3, immagine 2 di 3 How to clean the Brother HL-5240 corona wire, How to clean the Brother HL-5240 corona wire: passo 3, immagine 3 di 3
    • Clean the corona wire inside the drum unit by gently sliding the blue tab all the way to left and then back to the far right. Repeat several times.
    • Make sure the arrow on the tab lines up with the arrow on the drum unit before you place it back into the printer. If the tab is in the wrong place, a vertical line might appear on future print jobs.
Conclusione
Altre 2 persone hanno completato questa guida.
Nathan Ruiz
Membro da: 01/14/10
165 Reputazione
2 Guide realizzate
Cal Poly, Team 4-14, Forte Winter 2010 Membro di Cal Poly, Team 4-14, Forte Winter 2010
CPSU-FORTE-W10S4G14
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 29
Tutti i Tempi: 13,161
