Introduzione
This guide will walk you through taking apart the mouse and repairing the left and right mouse buttons.
Parti
Nessuna parte richiesta.
Unplug the USB cord to disconnect the mouse from power.
  • Unplug the USB cord to disconnect the mouse from power.
  • On the bottom side of the mouse, unscrew the single screw located above the rotating ball.
The screw on this mouse is a #2 phillips.
Brandon - Replica
Take off the top of the mouse and remove any debris located inside of the highlighted areas.
  • Take off the top of the mouse and remove any debris located inside of the highlighted areas.
  • Use a microfiber cloth first then, damp towel for areas that are more difficult to clean.
To take off the top part, you will want to lift the cover up just by a centimeter or two, and then slide it towards the back of the mouse while pulling up.
Brandon - Replica
  • The ball may be stuck or dirty and isn't relaying correctly. To remove or clean the ball, twist the ball cover according to the arrows (counter-clockwise).
Aggiungi Commento
  • These are the vertical and horizontal ball sensors. These can become dirty from excessive use. Clean these with proper materials to insure cooperation.
Aggiungi Commento
  • Insert the USB Cable back into your computer.
Aggiungi Commento
  • Examine the cord for frays or any exposed wires that may cause a bad connection.
Aggiungi Commento
  • Examine wheel for debris. The wheel can get dirty frequently which affects performance and may cause issues.
Aggiungi Commento
  • This highlights that the sensor may be dirty or broken.
Aggiungi Commento
  • The wheel button sensor may be stuck or not working. Pull the wheel out to expose it and clean it.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Montana Tech, Team 1-4, Shirk Fall 2014 Membro di Montana Tech, Team 1-4, Shirk Fall 2014
MTUM-SHIRK-F14S1G4
3 Membri
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 467
