Introduzione
we gonna clean the filters and the hoses, also the back and the pump.
if the machine is working but the laundry doesn't dry , you can follow these steps.
also if the machine is leaking water under the machine you can try to follow the steps.
Cosa ti serve
start with cleaning the filters inside the machine
unlock ( if possible , not all these machines inside filters are removable..) and clean out the filters using hot water and vinegar. there are tiny litlle holes in the filter , it is possible you will have to blow theme out with an compressor.
now we will clean out the bottom plate.
remove the plastic shell that is covering Torx screws.
remove it using a Stanley knife.
remove the screws ( at both sides ) and remove the plastic frame.
You'll see there will be a lot of dirt in the frame. blow (or vacuum clean) it. and put it back. also clean out the holes.
the machine is now clean and good to use again. I advise to do these hole guide one a year. Clean the "normal" filters everytime you use the machine. (just take out the fluff)
Altre 3 persone hanno completato questa guida.
1Commento della guida
Kevin D, thanks for the photos. I have a T8013C, which looks almost the same as this model. My dryer is in a small closet, so I can’t take it out to see the back…
In your photo 6, there is a hole next to the 4 bars. Accessing from the front of my dryer through the condenser housing, I can feel there is a lot of water in this hole. Is that normal? What is the purpose of this hole, shouldn’t the water be drained away? What happens when the water overflows the hole? Thanks.
