Salta al contenuto principale
How to clean a water damaged Nexus 5 Display
Cosa ti serve
    • I'm starting this guide with the front frame and LCD display, to do this you must complete all the steps on the Nexus 5 Teardown guide Smontaggio Nexus 5
    • In this video you can see the damage; the screen has lost touch sensitivity in the areas that are blank in this drawing program.
  1. How to clean a water damaged Nexus 5 Display, Separate the screen and the frame.: passo 2, immagine 1 di 2 How to clean a water damaged Nexus 5 Display, Separate the screen and the frame.: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Heat Gun
    $24.99
    • Flex what needs to be unstick
    • The flex is strongly stuck on the frame, to remove it warm with a Heat Gun.
  2. How to clean a water damaged Nexus 5 Display, Heating the screen at 50°C.: passo 3, immagine 1 di 2 How to clean a water damaged Nexus 5 Display, Heating the screen at 50°C.: passo 3, immagine 2 di 2
    • I used a multimeter with temperature measurement; it's not exact but it works.
    • Heating the edges.
  3. How to clean a water damaged Nexus 5 Display, Separating the screen and the frame.: passo 4, immagine 1 di 3 How to clean a water damaged Nexus 5 Display, Separating the screen and the frame.: passo 4, immagine 2 di 3 How to clean a water damaged Nexus 5 Display, Separating the screen and the frame.: passo 4, immagine 3 di 3
    • Be careful with the flex!
    • If you are installing a new LCD screen you must put it on the frame and follow all the steps in reverse order.
    • With a guitar pick you can separate the screen slowly.
  4. How to clean a water damaged Nexus 5 Display, Removing the layers on the screen.: passo 5, immagine 1 di 3 How to clean a water damaged Nexus 5 Display, Removing the layers on the screen.: passo 5, immagine 2 di 3 How to clean a water damaged Nexus 5 Display, Removing the layers on the screen.: passo 5, immagine 3 di 3
    • I used a hair dryer with cold air to help to separate the layers.
    • The first layer we need remove.
    • The second layer still on the frame of the screen.
    • The wet layers are on the screen
  5. How to clean a water damaged Nexus 5 Display, Removing the layers on the screen pt2: passo 6, immagine 1 di 3 How to clean a water damaged Nexus 5 Display, Removing the layers on the screen pt2: passo 6, immagine 2 di 3 How to clean a water damaged Nexus 5 Display, Removing the layers on the screen pt2: passo 6, immagine 3 di 3
    • use the guitar pick to separate the layers
    • 2nd layer
    • 3rd layer
  6. How to clean a water damaged Nexus 5 Display, Dry and clean.: passo 7, immagine 1 di 3 How to clean a water damaged Nexus 5 Display, Dry and clean.: passo 7, immagine 2 di 3 How to clean a water damaged Nexus 5 Display, Dry and clean.: passo 7, immagine 3 di 3
    • 3rd layer - don't separate.
    • 4th layer - don't separate.
    • 5th layer don't remove.
    • You can dry and clean all the layers (i use electrical contact cleaner).
  7. How to clean a water damaged Nexus 5 Display, Reassembling the layers.: passo 8, immagine 1 di 1
    • I cleaned all the layers perfectly with electronic contact cleaner.
    • Once you have cleaned and dried the layers you must reassemble in reverse order.
    • I'm very scared disassembling the layers of the screen, i thought it wouldn't work but despite everything worked.
    • I did this because i can't use the phone, the screen are marked by itself.
    • This screen is bad but it works almost perfectly as you can see on the video.
    • I must replace the LCD screen, but if you haven't money to replace and you want use which you have, this guide is perfect for you.
Conclusione
Altre 19 persone hanno completato questa guida.
Eneider Colina
Membro da: 09/20/13
2.370 Reputazione
9 Guide realizzate
2Commenti sulla guida
Hello, I dropped my Nexus 5 today and the front glass got broken; the LCD and the touch are working perfectly. Is it possible to only replace the front glass? Thanks
Mohamed Annous - Replica
Hello there. My Lg Nexus5-D821 phone just went blackout, that is had a dark screen when it was charging.nothing is showing on the screen even if you try to switch it on its failing to show anything on the screen. Someone looking at it is failing to diagnose its problem. He tested the battery on another phone is charging. What should I do to fix it. Kindly assist.
Beatrice - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 38
Tutti i Tempi: 68,089
