Salta al contenuto principale
How to clean a rusting Microwave
Cosa ti serve
  1. How to clean a rusting Microwave, Prepare the surface: passo 1, immagine 1 di 1
    • Unplug the microwave oven.
    • Clean the surface of all grease residue with alcohol or acetone.
  2. How to clean a rusting Microwave, Remove the rust: passo 2, immagine 1 di 1
    • Remove the glass tray and roller ring
    • Remove the stuck rust with steel wool.
    • Wipe away any debris with a dry cloth
  3. How to clean a rusting Microwave, Apply the paint: passo 3, immagine 1 di 1
    • Shake the tin
    • Apply a thin coat with the brush
    • Give the paint at least 6 hours to dry
    • Apply 1 or 2 more coats as appriopriate
  4. How to clean a rusting Microwave, Replace tray: passo 4, immagine 1 di 1
    • Allow time for the paint coatings to dry properly, ideally overnight with the door open.
    • Replace roller ring and tray. Plug your oven to the power outlet.
    • You are now ready to use your microwave oven again!
Linea Traguardo
Altre 21 persone hanno completato questa guida.
Tristan Hill
Membro da: 08/31/15
600 Reputazione
1 Guida realizzata
4Commenti sulla guida
Thanks so much!!! I got a small microwave from a rental unit ( it was rusted ans I thought i would be excellent for my fishing cabin ( in the wine country ). I WANTED TO USE EPOXY OR ENGINE PAINT!!! The mention set so many individuals at multiple sites off to saying things about toxic fumes and other ridiculous things. there’s even a special paint Amazon sells!!! https://www.google.com/search?client=fir...
wgcormier - Replica
So Easy thanks
Janet Jones - Replica
Thank you for the information.
Marci B Jeffcoats - Replica
Where do I buy the special paint
Diane Sauchuk - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 151
Tutti i Tempi: 63,567
