Introduzione
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
Parti
Nessuna parte richiesta.
  • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
  • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
Aggiungi Commento
Pull up on the tab to remove the batteries.
  • Pull up on the tab to remove the batteries.
  • Note: The batteries will probably fall out of their holder.
Aggiungi Commento
  • Your camera should look something like this.
  • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
Aggiungi Commento
  • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
Aggiungi Commento
  • All cleaned up!
Aggiungi Commento
Conclusione
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
Altre 3 persone hanno completato questa guida.
Zachary Phillips
Membro da: 08/04/2011
205 Reputazione
5 Guide realizzate
Cal Poly, Team 25-26, Garner Spring 2011 Membro di Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Membri
6 Guide realizzate
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 80
Tutti i Tempi: 11,345
