Salta al contenuto principale
How to clean Microtek ScanMaker 5900 surface glass
Cosa ti serve
  1. How to clean Microtek ScanMaker 5900 surface glass, Remove serial port connection: passo 1, immagine 1 di 3 How to clean Microtek ScanMaker 5900 surface glass, Remove serial port connection: passo 1, immagine 2 di 3 How to clean Microtek ScanMaker 5900 surface glass, Remove serial port connection: passo 1, immagine 3 di 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. How to clean Microtek ScanMaker 5900 surface glass, Remove Lid: passo 2, immagine 1 di 3 How to clean Microtek ScanMaker 5900 surface glass, Remove Lid: passo 2, immagine 2 di 3 How to clean Microtek ScanMaker 5900 surface glass, Remove Lid: passo 2, immagine 3 di 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. How to clean Microtek ScanMaker 5900 surface glass, How to clean Microtek ScanMaker 5900 surface glass: passo 3, immagine 1 di 1
    • Using a soft lint-free cloth clean the surface glass of dust, finger prints, and other debris.
Conclusione
Cal Poly, Team 6-9, Regan Fall 2011 Membro di Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membri
22 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,977
