Salta al contenuto principale
How to check or clean Samsung DVD-P230 buttons
Cosa ti serve
  1. How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: passo 1, immagine 1 di 3 How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: passo 1, immagine 2 di 3 How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: passo 1, immagine 3 di 3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. How to check or clean Samsung DVD-P230 buttons: passo 2, immagine 1 di 1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. How to check or clean Samsung DVD-P230 buttons: passo 3, immagine 1 di 1
    • Unscrew the 3 screws in the back.
  4. How to check or clean Samsung DVD-P230 buttons: passo 4, immagine 1 di 2 How to check or clean Samsung DVD-P230 buttons: passo 4, immagine 2 di 2
    • Pull the outer case upward and then towards you.
  5. How to check or clean Samsung DVD-P230 buttons: passo 5, immagine 1 di 3 How to check or clean Samsung DVD-P230 buttons: passo 5, immagine 2 di 3 How to check or clean Samsung DVD-P230 buttons: passo 5, immagine 3 di 3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. How to check or clean Samsung DVD-P230 buttons: passo 6, immagine 1 di 2 How to check or clean Samsung DVD-P230 buttons: passo 6, immagine 2 di 2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. How to check or clean Samsung DVD-P230 buttons, Power Cord: passo 7, immagine 1 di 3 How to check or clean Samsung DVD-P230 buttons, Power Cord: passo 7, immagine 2 di 3 How to check or clean Samsung DVD-P230 buttons, Power Cord: passo 7, immagine 3 di 3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. How to check or clean Samsung DVD-P230 buttons, Tray: passo 8, immagine 1 di 3 How to check or clean Samsung DVD-P230 buttons, Tray: passo 8, immagine 2 di 3 How to check or clean Samsung DVD-P230 buttons, Tray: passo 8, immagine 3 di 3
    • Remove the three screws holding in the DVD tray
  9. How to check or clean Samsung DVD-P230 buttons: passo 9, immagine 1 di 2 How to check or clean Samsung DVD-P230 buttons: passo 9, immagine 2 di 2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. How to check or clean Samsung DVD-P230 buttons: passo 10, immagine 1 di 2 How to check or clean Samsung DVD-P230 buttons: passo 10, immagine 2 di 2
    • Gently lift the DVD tray off of the motherboard.
  11. How to check or clean Samsung DVD-P230 buttons, How to check or clean Samsung DVD-P230 buttons: passo 11, immagine 1 di 1
    • Use the tweezers to make sure all the buttons aren't stuck.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 3-30, Regan Winter 2011 Membro di Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,479
