Salta al contenuto principale
How to change the grips on a golf club
Cosa ti serve
  1. How to change the grips on a golf club, Grip: passo 1, immagine 1 di 2 How to change the grips on a golf club, Grip: passo 1, immagine 2 di 2
    • Tighten golf club on vice clamp. Align the golf club so that the club face is vertical.
    • Note: Make sure you place container underneath the grip to catch excess mineral spray in later steps.
  2. How to change the grips on a golf club: passo 2, immagine 1 di 2 How to change the grips on a golf club: passo 2, immagine 2 di 2
    • With the xacto knife cut the old grip off of the club.
    • Remove grip from club.
  3. How to change the grips on a golf club: passo 3, immagine 1 di 2 How to change the grips on a golf club: passo 3, immagine 2 di 2
    • Measure the amount of double-sided tape necessary to cover the area of your grip.
    • Place the tape on the club so that it is centered and an extra inch comes off the end of the club.
  4. How to change the grips on a golf club: passo 4, immagine 1 di 2 How to change the grips on a golf club: passo 4, immagine 2 di 2
    • Squirt mineral spirits on the tape.
    • Make sure you drench the tape in mineral spirits.
    • Note: it is safe to get mineral spirits on your skin, it is non-toxic.
  5. How to change the grips on a golf club: passo 5, immagine 1 di 3 How to change the grips on a golf club: passo 5, immagine 2 di 3 How to change the grips on a golf club: passo 5, immagine 3 di 3
    • While the tape still has mineral spray on it, quickly slide the grip all the way down.
  6. How to change the grips on a golf club: passo 6, immagine 1 di 1
    • Wait 1-2 hours for the mineral spray to dry.
Conclusione
Cal Poly, Team 30-2, Green Spring 2015 Membro di Cal Poly, Team 30-2, Green Spring 2015
CPSU-GREEN-S15S30G2
4 Membri
4 Guide realizzate
1Commento della guida
Muy bueno. Gracias
Matias Doro Altan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,411
