Introduzione
In this video tutorial, I will show you how to calibrate a gimbal camera on a DJI Mavic Mini. This process is necessary after replacing the camera stabilizer, gimbal assembly, or changing the drone motherboard.
Download Programs for Calibration Gimbal :
- Python: https://www.python.org/
- PySerial: https://pypi.org/project/pyserial/#files
- GitHub: https://github.com/o-gs/dji-firmware-too...
- 7-zip: https://7-zip.org/
First script to run calibration
- py comm_og_service_tool.py --port com pcode GimbalCalib JointCoarse
Second gimbal calibration script
- py comm_og_service_tool.py --port com pcode GimbalCalib LinearHall
Istruzioni Video
To reassemble your device, follow these instructions.
9Commenti sulla guida
Does this work for the dji mini se? As I do not see a pcode in the list.
Joshua Dockery - Rispondi Condividi
Thank you for your video, for me it gets stuck in the "Info: The Gimbal will slowly move through all positions in all axes," and not responding.. any ideas? Thank you.
Βασίλης Τριανταφύλλου - Rispondi Condividi
Gimbal still is facing to the left
Luis Royo - Rispondi Condividi
When I put in the py setup.py install command, I get an error message. File
not found or something similar. I’ve tried redownloading and tried different versions of py and pyserial 3.5. Any advice?
Dji mini - Rispondi Condividi
Hi, this post from other forum helped me with this problem
Here are the steps to fix these issues:
Install setuptools: If setuptools is not installed, you can install it via pip, the Python package installer. Open your Command Prompt and run the following command: Copy this code
python -m pip install setuptools
Make sure that you have pip installed and that it is added to your system's PATH.
Check Python installation: The distutils module should be included with your Python installation. If it's missing, it suggests that there may be an issue with your Python installation. You might need to reinstall Python. Ensure that you download Python from the official Python website and install it, including the "Add Python to PATH" option during installation.
Paulius Zemaitis - Rispondi Condividi
