Salta al contenuto principale
How to apply an Adhesive Bandage on a Fingertip
Cosa ti serve
  1. How to apply an Adhesive Bandage on a Fingertip, Cut the bandage: passo 1, immagine 1 di 3 How to apply an Adhesive Bandage on a Fingertip, Cut the bandage: passo 1, immagine 2 di 3 How to apply an Adhesive Bandage on a Fingertip, Cut the bandage: passo 1, immagine 3 di 3
    • Cut the bandage strip to length.
    • You need twice the length you want the bandage to cover. A 5 to 6 cm strip is usually enough for most small cuts.
    • Now, carefully cut a small triangle out of the bandage on both adhesive sides, up to the gauze pad. Cut the triangles out exactly in the middle. This will create four "little wings", as seen in the second picture.
  2. How to apply an Adhesive Bandage on a Fingertip, Peel off the protective films: passo 2, immagine 1 di 2 How to apply an Adhesive Bandage on a Fingertip, Peel off the protective films: passo 2, immagine 2 di 2
    • Peel off the protective films from the adhesive strip of the bandage.
  3. How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: passo 3, immagine 1 di 3 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: passo 3, immagine 2 di 3 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: passo 3, immagine 3 di 3
    • Place your finger on the bandage so that the tip of the finger meets the center line.
    • Fold up the two "little wings" on the side facing you one by one and secure them on the top side of the finger.
  4. How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: passo 4, immagine 1 di 3 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: passo 4, immagine 2 di 3 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: passo 4, immagine 3 di 3
    • Pull the bandage as tightly as possible over the fingertip towards the back and turn the finger with the underside facing upward.
    • Fold up the two remaining "little wings" one by one and secure them on the underside of the finger.
Conclusione
If you have chosen the correct size of bandage, placed it properly, and pressed it firmly, it should now cover the entire fingertip. The wound should not come into contact with the adhesive surfaces.
Altre 5 persone hanno completato questa guida.
Sebastian
Membro da: 08/19/18
31.160 Reputazione
71 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 66
Ultimi 7 Giorni: 490
Ultimi 30 Giorni: 2,032
Tutti i Tempi: 28,306
