Salta al contenuto principale
How to access hidden settings on RCA RT2806
  1. How to access hidden settings on RCA RT2806, Power: passo 1, immagine 1 di 1
    • Turn on your TV
  2. How to access hidden settings on RCA RT2806, Open the Menu: passo 2, immagine 1 di 2 How to access hidden settings on RCA RT2806, Open the Menu: passo 2, immagine 2 di 2
    • Open the menu, by pressing the menu button on the remote
  3. How to access hidden settings on RCA RT2806, NumPad Shortcut: passo 3, immagine 1 di 2 How to access hidden settings on RCA RT2806, NumPad Shortcut: passo 3, immagine 2 di 2
    • Press the following buttons quickly after opening the menu:
    • 1-1-4-7
    • This is a column of numbers on your NumPad
    • If it doesn't work, do it more quickly after opening the menu, and check your TV model number.
Conclusione
To close the new menu, press EXIT
Altre 2 persone hanno completato questa guida.
9021007
Membro da: 07/13/18
4.599 Reputazione
25 Guide realizzate
3 Commenti
You can disable the dog logo on here under General Settings.
9021007 - Replica
Thank you very much. This was driving me insane
Will McCreary -
Is there any way to save settings? Some settings are permanent, but specifically the overscan settings are reset to their original values when I power the screen off, whether by the remote power button, the power button on the screen itself. or by unplugging it.
Please advise.
Jyri Keir - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 70
Tutti i Tempi: 2,705
