Salta al contenuto principale
How to Wire a RJ-45 KeyStone Jack
Cosa ti serve
  1. How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: passo 1, immagine 1 di 3 How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: passo 1, immagine 2 di 3 How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: passo 1, immagine 3 di 3
  2. How to Wire a RJ-45 KeyStone Jack: passo 2, immagine 1 di 3 How to Wire a RJ-45 KeyStone Jack: passo 2, immagine 2 di 3 How to Wire a RJ-45 KeyStone Jack: passo 2, immagine 3 di 3
    • Use your wire stripper to cut the outer sheath
    • Do Not Rotate more than 3-4 times as it will cut the wires underneath.
    • when the length of exposed wires are at a decent length (a little less than a thumbs length) separate the wires by color.
  3. How to Wire a RJ-45 KeyStone Jack: passo 3, immagine 1 di 3 How to Wire a RJ-45 KeyStone Jack: passo 3, immagine 2 di 3 How to Wire a RJ-45 KeyStone Jack: passo 3, immagine 3 di 3
    • on the keystone jack you will see colors. line the wires up to the corresponding colors (white blue - blue, white orange - orange, etc.)
    • use the punchdown tool with the longer side of the blade on the outside to punch the wires in and it will cut off the excess.
    • repeat for each color
  4. How to Wire a RJ-45 KeyStone Jack: passo 4, immagine 1 di 3 How to Wire a RJ-45 KeyStone Jack: passo 4, immagine 2 di 3 How to Wire a RJ-45 KeyStone Jack: passo 4, immagine 3 di 3
    • open up your mounting box
    • there should be a frame for your jack to snap into
  5. How to Wire a RJ-45 KeyStone Jack: passo 5, immagine 1 di 2 How to Wire a RJ-45 KeyStone Jack: passo 5, immagine 2 di 2
    • place the jack into the mounting box, there should be places for zip ties to hold the cable in place
    • place the cover on top and you are done with your cable!
    • test the line using a cable tester.
Conclusione
Make Sure to test with a cable tester
Altre 6 persone hanno completato questa guida.
Samuel Lynch
Membro da: 04/24/18
293 Reputazione
1 Guida realizzata
Sams TechRepair Membro di Sams TechRepair
Business
1 Membro
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 80
Ultimi 30 Giorni: 296
Tutti i Tempi: 23,220
