Salta al contenuto principale
How to Wipe Samsung Galaxy S4 Data / Factory Reset
Panoramica Video
  1. How to Wipe Samsung Galaxy S4 Data / Factory Reset, How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 1, immagine 1 di 2 How to Wipe Samsung Galaxy S4 Data / Factory Reset, How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 1, immagine 2 di 2
    • Turn off the phone. Press and hold at the same time Volume UP,Home and Power keys. When you see Galaxy logo release the Power key but continue to hold the Volume Up key and the Home key.
  2. How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 2, immagine 1 di 3 How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 2, immagine 2 di 3 How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 2, immagine 3 di 3
    • Release them when the Android System Recovery screen appears. Use Volume Up/Down keys for navigation and Power On key for OK. Choose "wipe cache partition", "Yes -- delete all user data", "reboot system now".
  3. How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 3, immagine 1 di 3 How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 3, immagine 2 di 3 How to Wipe Samsung Galaxy S4 Data / Factory Reset: passo 3, immagine 3 di 3
    • That's all.
    • Did you do it successfully?
Conclusione
This guide does not require resassembly.
Altre 283 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.368 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.468 Guide realizzate
31 Commenti
Here my recommendation is a data eraser named Android Data Eraser, which can erase all Android data including contacts, messages, call history, apps, system setting, photo, video, etc. Indeed, Android Data Eraser worth trusting and it makes the work more effective. What you need is a windows computer. One single click and data deletion finish.
http://www.recover-iphone-android.com/er...
yisdddcbrown - Replica
easy to follow instructions but does not work have done it 3 times now and get to a step which requires to do a factory reset. Phone the automatically switches off and loses connection with program and have to start all over again. Goes round in circles with a factory reset the only result - and you can do that without downloading the program.
maser222e -
why would you bother when you can factory reset in 1 min???
rickialison -
Deleted data from samsung phone are recoverable with Coolmuster Samsung Recovery software. But you need to follow special steps as droid phone`s memory is not accessible easily.
http://www.samsung-recovery.net/
Swolsteedd - Replica
Hi Can the software recover my calendar after I mistakenly did a factory wipe?
Helene Zinberg -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 116
Ultimi 30 Giorni: 557
Tutti i Tempi: 1,123,065
