Salta al contenuto principale
How to Use a Multimeter for Appliance Repairs
Guida video
Questa guida è stata trascritta da un video di YouTube.
Cosa ti serve
    • Unplug the appliance or shut off the breaker before doing continuity or resistance tests.
    • WARNING: Treat live voltage testing as hazardous, and only do it if you’re comfortable working around energized connections.
    • Use insulated gloves for live tests, and touch only the insulated probe handles.
    Chiedi a FixBot
    Aggiungi Commento
    • Use a multimeter to check whether an electrical signal can travel between two points.
    • Set the dial to the function you want, then place one probe on each point you want to compare.
    • Depending on the meter and the mode, results show on a digital display, an analog readout, or as a tone.
    Chiedi a FixBot
    Aggiungi Commento
    • Turn the dial to continuity, which is often shown as a sound-wave or Wi‑Fi-like symbol.
    • Touch the probe tips together to confirm the meter beeps and reacts on the display.
    • Touch one probe to each end of the part or wire you’re checking to see whether it can pass a signal from point A to point B.
    • A beep usually means the circuit path is present, and no beep usually means the path is broken.
    Chiedi a FixBot
    Aggiungi Commento
    • Set the meter to continuity to test a thermal fuse.
    • Place the probes on the fuse’s metal terminals to check for a signal.
    • Probe the rear metal connections if the probe tips won’t fit well from the front of the connector.
    • Treat a fuse like a pass-or-fail part, because it should pass electricity when it’s good and block it when it’s blown.
    Chiedi a FixBot
    Aggiungi Commento
    • Remove at least one spade terminal from the component you’re testing so the reading doesn’t backfeed through the rest of the appliance.
    • Touch the probes only to the two points that belong to the component you want to measure.
    • Use this isolation habit for heating elements, sensors, motors, and wiring you’re checking inside a unit.
    Chiedi a FixBot
    Aggiungi Commento
    • Watch for an OL reading, which indicates an open line and no connection between the probes.
    • Check heating element terminals with the probes to get a resistance value instead of OL when the element is intact.
    • Expect a heater element like the example to read about 10 to 20 ohms, and treat OL as a sign the internal coil is broken.
    Chiedi a FixBot
    Aggiungi Commento
    • Set the meter to continuity and place one probe on a heater spade terminal.
    • Place the other probe on the heater’s metal cabinet or chassis to see whether the heater is electrically connected to the cabinet.
    • Treat a continuity connection from a heater terminal to the cabinet as a grounding situation that can be very dangerous.
    • A grounded heater can cause unwanted heating and can burn out sensors acting as safety switches.
    Chiedi a FixBot
    Aggiungi Commento
    • Use resistance when a component needs both continuity and a specific ohms value to confirm the coil is wound properly.
    • Measure across the two motor or coil leads and compare the reading to the expected specification for the part or model.
    • Re-seat the probes if the number jumps, because readings can change based on how solid the probe contact is.
    Chiedi a FixBot
    Aggiungi Commento
    • Measure resistance on a sensor by placing the probes on its two terminals, using the rear metal connections when needed.
    • Expect some sensors to have a target value at room temperature, like about 5,000 ohms for the example defrost sensor.
    • Watch the number change as the sensor warms or cools, because temperature changes shift resistance and the control uses that information.
    • Consider a sensor suspect if it’s off spec, because it can make the appliance “think” it’s hotter or colder than it really is.
    Chiedi a FixBot
    Aggiungi Commento
    • Measure resistance across the thermistor’s terminals and note the starting value, which can be around 10,000 ohms in the example.
    • Warm the sensing area with a finger and watch the resistance drop as it heats up.
    • Remove your finger and watch the resistance climb again as the sensor cools.
    Chiedi a FixBot
    Aggiungi Commento
    • WARNING: Do live voltage tests only with the meter set correctly, using probe leads and insulated gloves.
    • Turn the dial to AC voltage, which is shown with a squiggly line, not the straight line and dots used for DC voltage on circuit boards.
    • Press the probes against the connection posts to measure voltage between posts without touching the metal with your fingers.
    • On a typical US stove connection, check for about 240 volts across the two side posts and about 120 volts from each side post to the middle.
    • Remember that voltage is only the potential between two points, not the actual current flowing at that moment.
    Chiedi a FixBot
    Aggiungi Commento
    • Turn the clamp meter to the A setting and use the lowest appliance range, usually between 2 and 20 amps.
    • Turn the appliance function on and read the current draw to see what it’s actually consuming.
    • Clamp around only one wire, because clamping around both hot and neutral cancels the reading out.
    • Separate the wires so only a single conductor is inside the clamp jaw.
    Chiedi a FixBot
    Aggiungi Commento
    • Use amperage on a gas stove igniter circuit to confirm whether it’s drawing enough current to open the safety valve.
    • Look for about 3 amps in the example, because an igniter can glow but still fail to draw enough current to light the burner.
    • Use amperage on a refrigerator compressor wire to see how much work the compressor motor is doing.
    • Compare the compressor’s reading to the expected value for that model, because low current can indicate a refrigerant-related problem.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Use continuity for simple pass-or-fail parts like fuses and for checking wiring paths, use resistance to confirm coils and sensors are in spec, use AC voltage to verify power is actually present, and use a clamp meter to see what current a load is really drawing. Recheck probe contact if readings seem odd, and isolate components by removing at least one terminal whenever possible. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
Membro da: 01/21/25
7.079 Reputazione
224 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 45
Ultimi 30 giorni: 188
Tutti i Tempi: 1,089
