Salta al contenuto principale
How to Unclog an Epson ET-2760 Printhead
Cosa ti serve
  1. How to Unclog an Epson ET-2760 Printhead, How to Unclog an Epson ET-2760 Printhead: passo 1, immagine 1 di 2 How to Unclog an Epson ET-2760 Printhead, How to Unclog an Epson ET-2760 Printhead: passo 1, immagine 2 di 2
    • Begin a print of any kind, or a nozzle check.
    • Once the print has begun, pull the power cable out mid-print.
  2. How to Unclog an Epson ET-2760 Printhead: passo 2, immagine 1 di 2 How to Unclog an Epson ET-2760 Printhead: passo 2, immagine 2 di 2
    • Open the printer, then pull out the half-printed paper through the slot.
    • Place a thick paper towel or rag under the printhead.
  3. How to Unclog an Epson ET-2760 Printhead: passo 3, immagine 1 di 3 How to Unclog an Epson ET-2760 Printhead: passo 3, immagine 2 di 3 How to Unclog an Epson ET-2760 Printhead: passo 3, immagine 3 di 3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Unclip the two white plastic clips.
    • Lift the top cover off of the printhead.
  4. How to Unclog an Epson ET-2760 Printhead: passo 4, immagine 1 di 1
    • Unclip the four ink cartridges from the printhead by pulling the small tabs on top of the cartridges.
    • Be sure not to disconnect the ink lines from the cartridges. Simply set the connected cartridges to the side of the printhead.
  5. How to Unclog an Epson ET-2760 Printhead: passo 5, immagine 1 di 2 How to Unclog an Epson ET-2760 Printhead: passo 5, immagine 2 di 2
    • Fill a syringe with printhead cleaning solution and place the syringe tip over the holes left by the cartridges.
  6. How to Unclog an Epson ET-2760 Printhead: passo 6, immagine 1 di 1
    • Begin to flush the manufacturer's recommended amount of solution through each hole onto the paper towel.
    • If necessary, swap out the paper towel in between flushes to prevent any solution from entering the printer.
  7. How to Unclog an Epson ET-2760 Printhead: passo 7, immagine 1 di 1
    • Remove the paper towel from under the printhead.
  8. How to Unclog an Epson ET-2760 Printhead: passo 8, immagine 1 di 3 How to Unclog an Epson ET-2760 Printhead: passo 8, immagine 2 di 3 How to Unclog an Epson ET-2760 Printhead: passo 8, immagine 3 di 3
    • Reattach each ink cartridge into their original positions.
    • Reattach the two printhead cover clips back onto the printhead.
    • Screw the single screw back into place with a Phillips #0 screwdriver.
  9. How to Unclog an Epson ET-2760 Printhead: passo 9, immagine 1 di 1
    • Perform an automatic cleaning to ensure that any ink residue is removed.
Conclusione
Enjoy your clean printhead!
Altre 11 persone hanno completato questa guida.
20 Commenti
Simple but to the point tutorial that detailed every step including the tools and supplies needed. Photos helped tremendously too. Thank you.
Mark DiRollo - Replica
Where do I find out the "manufacturer's recommended amount of solution" per flush?
Stelios Makrinos - Replica
Usually it's 5ml
Casper Hon -
But it seems that ink isn't even getting to my yellow and blue heads. At least, the test print shows no yellow or blue at all.
How can I get at the exit (valves?) on the ink storage tanks to make sure they're clear -- without breaking the printer?
Thanks!
warble58 - Replica
Me too! No yellow or blue coming through.
Tracy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 58
Ultimi 7 Giorni: 541
Ultimi 30 Giorni: 2,385
Tutti i Tempi: 54,902
