Salta al contenuto principale
How to Unclog a Toilet with an Auger
Cosa ti serve
  1. How to Unclog a Toilet with an Auger, How to Unclog a Toilet with an Auger: passo 1, immagine 1 di 2 How to Unclog a Toilet with an Auger, How to Unclog a Toilet with an Auger: passo 1, immagine 2 di 2
    • Turn the auger's handle counterclockwise and pull it towards you to retract the snake.
  2. How to Unclog a Toilet with an Auger: passo 2, immagine 1 di 2 How to Unclog a Toilet with an Auger: passo 2, immagine 2 di 2
    • Place the auger directly into the toilet bowl.
    • The end of the auger can scratch the toilet bowl, so use caution.
  3. How to Unclog a Toilet with an Auger: passo 3, immagine 1 di 1
    • Turn the handle clockwise to push the auger down the drain.
    • Stop when the handle gets stiff.
  4. How to Unclog a Toilet with an Auger: passo 4, immagine 1 di 2 How to Unclog a Toilet with an Auger: passo 4, immagine 2 di 2
    • Turn the handle counterclockwise while pulling it towards you to retract the auger.
    • Remove the auger from the toilet and dispose of anything caught by the metal.
  5. How to Unclog a Toilet with an Auger: passo 5, immagine 1 di 1
    • Flush the toilet to see if the water resets to a normal level.
    • Be prepared to push and retract the auger multiple times to clear the clog.
  6. How to Unclog a Toilet with an Auger: passo 6, immagine 1 di 1
    • Once the toilet is unclogged, place the auger in a towel to dry.
Linea Traguardo
Dante
Membro da: 01/16/24
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 154
