Salta al contenuto principale
How to Unclog a Toilet Drainpipe
Cosa ti serve
  1. How to Unclog a Toilet Drainpipe, How to Unclog a Toilet Drainpipe: passo 1, immagine 1 di 1
    • Turn off the water supply.
    • The switch of water supply may locate differently depends on different pipe structure. Find it either left or right of toilet bowl on the floor.
  2. How to Unclog a Toilet Drainpipe: passo 2, immagine 1 di 1
    • Flush the toilet in order to empty the water tank and the bowl.
  3. How to Unclog a Toilet Drainpipe: passo 3, immagine 1 di 1
    • Use a sponge or paper towel to clean the water left in the water tank.
    • Make sure you wear the gloves.
  4. How to Unclog a Toilet Drainpipe: passo 4, immagine 1 di 1
    • Remove the water supply pipe from the toilet bowl.
  5. How to Unclog a Toilet Drainpipe: passo 5, immagine 1 di 3 How to Unclog a Toilet Drainpipe: passo 5, immagine 2 di 3 How to Unclog a Toilet Drainpipe: passo 5, immagine 3 di 3
    • Find the floor bolts and remove the decorative cap off the bolts.
    • Remove the bolts with a wrench.
  6. How to Unclog a Toilet Drainpipe: passo 6, immagine 1 di 1
    • After removing the floor bolts, wiggle the bowl and remove it.
    • Remove anything that may be stuck in the pipe.
Conclusione
Chen Liang
Membro da: 07/08/20
160 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,431
