Salta al contenuto principale
How to Unclog a Shark Rocket Deluxe Pro Vacuum
Cosa ti serve
  1. How to Unclog a Shark Rocket Deluxe Pro Vacuum, How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 1, immagine 1 di 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum, How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 1, immagine 2 di 2
    • Press the wand release button to remove the vacuum body from the roller brush and wand.
  2. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 2, immagine 1 di 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 2, immagine 2 di 2
    • Press the button at the bottom of the power cord on the dust bin.
    • Pull off the attached piece.
    • Remove the small filter from the piece.
  3. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 3, immagine 1 di 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 3, immagine 2 di 2
    • Pull the lever on top of the dust bin to expose the main filters.
  4. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 4, immagine 1 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 4, immagine 2 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 4, immagine 3 di 3
    • Carefully squeeze and remove the top filter.
    • Underneath that filter is a second filter. Pull the tab to remove it.
  5. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 5, immagine 1 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 5, immagine 2 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 5, immagine 3 di 3
    • Squeeze the release on the bottom of the dustbin.
    • Remove the dust bin from the base.
    • Pop the lid open using the slider.
    • Empty the dust bin into the trash.
  6. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 6, immagine 1 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 6, immagine 2 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 6, immagine 3 di 3
    • Rinse and wipe the plastic pieces removed earlier.
    • Do not use soap.
    • Set the pieces aside to air-dry.
  7. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 7, immagine 1 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 7, immagine 2 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 7, immagine 3 di 3
    • Place the filters in your sink and rinse out the dirt.
    • Squeeze out any excess water and allow them to air-dry overnight before reinstalling.
    • DO NOT USE SOAP.
  8. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 8, immagine 1 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 8, immagine 2 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 8, immagine 3 di 3
    • With a wet rag wipe out any dirt buildup on the vacuum casing.
  9. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 9, immagine 1 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 9, immagine 2 di 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 9, immagine 3 di 3
    • Turn the base of the vacuum on its side.
    • With your scissors, cut any wrapped hairs or strings that may be stuck on the rollers.
  10. How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 10, immagine 1 di 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum: passo 10, immagine 2 di 2
    • Lastly, insert your drain snake into the tube of the vacuum to dislodge any large stuck items.
Conclusione
Savannah Webb
Membro da: 06/13/21
181 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 87
Tutti i Tempi: 1,878
