Salta al contenuto principale
How to Unclog a Samsung WF350ANR Washing Machine Filter
Cosa ti serve
  1. How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 1, immagine 1 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 1, immagine 2 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 1, immagine 3 di 3
    • Caution: Before beginning this guide, be sure to turn the washing machine off and unplug it from the outlet.
    • The water filter is typically located at the bottom right or bottom left. In this case, it is located at the bottom right.
    • Place a bucket under the water filter to capture excess water before moving on to the next steps.
  2. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 2, immagine 1 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 2, immagine 2 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 2, immagine 3 di 3
    • Jiggle the water filter compartment while pulling it towards yourself to remove the compartment.
  3. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 3, immagine 1 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 3, immagine 2 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 3, immagine 3 di 3
    • To open the water filter, move the knob to the left with your hand.
    • With your other hand, hold the bucket underneath the filter to capture the excess water.
  4. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 4, immagine 1 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 4, immagine 2 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 4, immagine 3 di 3
    • Remove the water filter.
    • Clean hard-to-reach places in the filter with a toothbrush and excess water that was captured with the bucket.
  5. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 5, immagine 1 di 2 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 5, immagine 2 di 2
    • Use the toothbrush to clean the slot in the washing machine where the water filter is inserted.
  6. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 6, immagine 1 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 6, immagine 2 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 6, immagine 3 di 3
    • Inspect the inside to make sure there is no leftover lint or unnecessary objects that can clog the water filter.
  7. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 7, immagine 1 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 7, immagine 2 di 3 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 7, immagine 3 di 3
    • Place the water filter back into the washing machine.
    • Turn the filter to the right to tighten it.
  8. How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 8, immagine 1 di 2 How to Unclog a Samsung WF350ANR Washing Machine Filter: passo 8, immagine 2 di 2
    • Pour the bucket of excess water down a drain.
    • If a lot of lint or hair was cleaned out of the water filter, make sure to grab it with one hand as you drain out the water with the other hand.
    • Discard the lint and hair in the trash.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 59
Tutti i Tempi: 1,232
