Salta al contenuto principale
How to Unclog a Keurig K-Classic Coffee Maker
Cosa ti serve
  1. How to Unclog a Keurig K-Classic Coffee Maker, How to Unclog a Keurig K-Classic Coffee Maker: passo 1, immagine 1 di 2 How to Unclog a Keurig K-Classic Coffee Maker, How to Unclog a Keurig K-Classic Coffee Maker: passo 1, immagine 2 di 2
    • Unplug the Keurig and take off the water reservoir.
  2. How to Unclog a Keurig K-Classic Coffee Maker: passo 2, immagine 1 di 2 How to Unclog a Keurig K-Classic Coffee Maker: passo 2, immagine 2 di 2
    • Empty out the water reservoir, then remove the water filter.
  3. How to Unclog a Keurig K-Classic Coffee Maker: passo 3, immagine 1 di 1
    • Use a bobby pin to clean the bottom of the dispenser.
  4. How to Unclog a Keurig K-Classic Coffee Maker: passo 4, immagine 1 di 2 How to Unclog a Keurig K-Classic Coffee Maker: passo 4, immagine 2 di 2
    • Fill the water reservoir about halfway with white vinegar, then fill the rest of the water reservoir with water.
  5. How to Unclog a Keurig K-Classic Coffee Maker: passo 5, immagine 1 di 1
    • Plug in the machine and run without a K-cup, then start brewing.
  6. How to Unclog a Keurig K-Classic Coffee Maker: passo 6, immagine 1 di 1
    • Let the machine rest for 45 minutes to soak.
    • The power can be left on.
  7. How to Unclog a Keurig K-Classic Coffee Maker: passo 7, immagine 1 di 1
    • Remove the water reservoir and rinse out with fresh water to remove any leftover vinegar.
  8. How to Unclog a Keurig K-Classic Coffee Maker: passo 8, immagine 1 di 1
    • Place the water filter back in the water reservoir.
    • Place the lid back on top of the water reservoir, and insert entire part back on the Keurig.
Linea Traguardo
Texas Tech, Team S9-G3, Cowan Fall 2020 Membro di Texas Tech, Team S9-G3, Cowan Fall 2020
TTU-COWAN-F20S9G3
2 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 46
Tutti i Tempi: 1,817
