Salta al contenuto principale
How to Unclog a Keurig BVMC-KG5
Cosa ti serve
  1. How to Unclog a Keurig BVMC-KG5, How to Unclog a Keurig BVMC-KG5: passo 1, immagine 1 di 1
    • Unplug your Keurig.
  2. How to Unclog a Keurig BVMC-KG5: passo 2, immagine 1 di 1
    • Disassemble all of the parts. This includes: water tank, lid, K-cup holder, and both pieces of the tray where the coffee cup sits.
    • You should not need a screwdriver for this. All of the parts you are disassembling are easily removable by hand.
    • Wash all of the parts in warm, soapy water. Dry well.
  3. How to Unclog a Keurig BVMC-KG5: passo 3, immagine 1 di 3 How to Unclog a Keurig BVMC-KG5: passo 3, immagine 2 di 3 How to Unclog a Keurig BVMC-KG5: passo 3, immagine 3 di 3
    • Unclog the needles using a slightly bent paperclip.
    • With the top of the Keuring open, insert the free end of the paperclip into the three small holes surrounding the needle that pierces the K-Cup.
    • Jiggle the paperclip to loosen any debris.
  4. How to Unclog a Keurig BVMC-KG5: passo 4, immagine 1 di 1
    • Wipe the whole machine down and reassemble all of the previously removed parts.
  5. How to Unclog a Keurig BVMC-KG5: passo 5, immagine 1 di 1
    • Fill the water tank with a half water-half vinegar solution.
    • Do not use straight vinegar. It can damage the machine's parts due to the acidity.
    • Run the water-vinegar solution through the machine until you have emptied the tank.
    • Run clean water through the machine. You may have to repeat this step several times to get all of the water-vinegar solution out of the pipes.
Conclusione
Repeat this process every 2-3 months for optimal use of your Keurig, and to increase the lifespan of your coffee brewer.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 5,667
