Salta al contenuto principale
How to True a Bicycle Wheel with Zip Ties
Cosa ti serve
  1. How to True a Bicycle Wheel with Zip Ties, How to True a Bicycle Wheel with Zip Ties: passo 1, immagine 1 di 1
    • Place your bike upside down.
  2. How to True a Bicycle Wheel with Zip Ties: passo 2, immagine 1 di 1
    • Tie a zip tie next to the rim of your wheel.
  3. How to True a Bicycle Wheel with Zip Ties: passo 3, immagine 1 di 2 How to True a Bicycle Wheel with Zip Ties: passo 3, immagine 2 di 2
    • Cut the zip tie.
    • The zip tie should barely touch the rim.
  4. How to True a Bicycle Wheel with Zip Ties: passo 4, immagine 1 di 1
    • Spin the wheel and mark the spots where the rim touches the zip tie.
  5. How to True a Bicycle Wheel with Zip Ties: passo 5, immagine 1 di 2 How to True a Bicycle Wheel with Zip Ties: passo 5, immagine 2 di 2
    • Slowly loosen the spoke that is on the side of the zip tie.
    • Slowly tighten the spoke that is away from the zip tie.
    • Turn clockwise to tighten and counterclockwise to loosen.
  6. How to True a Bicycle Wheel with Zip Ties: passo 6, immagine 1 di 1
    • Repeat steps 2 to 5 with the zip tie on the other side of the wheel.
Conclusione
Repeat the instructions on your other wheel.
Niyoosha Tahami
Membro da: 07/02/24
133 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 95
Tutti i Tempi: 556
