Salta al contenuto principale
How to True a Bent Bicycle Rim Using Common Tools
Cosa ti serve
  1. How to True a Bent Bicycle Rim Using Common Tools, How to True a Bent Bicycle Rim Using Common Tools: passo 1, immagine 1 di 1
    • Bring your bike somewhere with ample space so you have room to work.
  2. How to True a Bent Bicycle Rim Using Common Tools: passo 2, immagine 1 di 3 How to True a Bent Bicycle Rim Using Common Tools: passo 2, immagine 2 di 3 How to True a Bent Bicycle Rim Using Common Tools: passo 2, immagine 3 di 3
    • Flip the bike on its seat so the wheel can spin freely.
    • Use the spokes to spin the affected wheel.
    • Continue spinning the wheel until it is clear where the bend is occurring.
  3. How to True a Bent Bicycle Rim Using Common Tools: passo 3, immagine 1 di 2 How to True a Bent Bicycle Rim Using Common Tools: passo 3, immagine 2 di 2
    • Locate the bend by spinning the wheel to see where it doesn't align with the brake.
  4. How to True a Bent Bicycle Rim Using Common Tools: passo 4, immagine 1 di 3 How to True a Bent Bicycle Rim Using Common Tools: passo 4, immagine 2 di 3 How to True a Bent Bicycle Rim Using Common Tools: passo 4, immagine 3 di 3
    • Locate the two nearest spoke nipples opposite to the bend direction and tighten them a half turn using an adjustable wrench or reaming pliers.
  5. How to True a Bent Bicycle Rim Using Common Tools: passo 5, immagine 1 di 2 How to True a Bent Bicycle Rim Using Common Tools: passo 5, immagine 2 di 2
    • Pluck the spoke and listen to the pitch to check its tightness.
    • If the pitch is higher, you are tightening it, and if the pitch is lower, you are loosening it.
  6. How to True a Bent Bicycle Rim Using Common Tools: passo 6, immagine 1 di 2 How to True a Bent Bicycle Rim Using Common Tools: passo 6, immagine 2 di 2
    • Loosen the spoke nipples opposite to the ones being tightened to reduce stress in the wrong direction.
  7. How to True a Bent Bicycle Rim Using Common Tools: passo 7, immagine 1 di 1
    • Assess the dent in the bike rim and assure it's mostly straightened out relative to the break pad.
    • Repeat the tightening/loosening process accordingly if necessary.
Conclusione
UCD-MORRIS-S23S1G4 Membro di UCD-MORRIS-S23S1G4
Community
2 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 43
Tutti i Tempi: 1,484
