Salta al contenuto principale
How to Tighten the Nishiki Aero II Chain
  1. How to Tighten the Nishiki Aero II Chain, How to Tighten the Nishiki Aero II Chain: passo 1, immagine 1 di 1
    • Shift the rear derailleur into its outermost gear, and the front derailleur into its outer gear.
  2. How to Tighten the Nishiki Aero II Chain: passo 2, immagine 1 di 3 How to Tighten the Nishiki Aero II Chain: passo 2, immagine 2 di 3 How to Tighten the Nishiki Aero II Chain: passo 2, immagine 3 di 3
    • Open the quick-release lever on the rear axle.
    • Quick-release levers are designed to allow you to remove a wheel by hand, with no tools.
    • Continue to loosen the axle by hand until you can freely move the axle in its notch in the rear fork.
  3. How to Tighten the Nishiki Aero II Chain: passo 3, immagine 1 di 1
    • Move the axle farther back along the notch in the fork so that the chain is taught between the cogs.
    • You might want to ask a friend to help you keep everything steady.
    • Be careful when choosing the new position for the axle; make sure that the wheel will be aligned with the frame.
  4. How to Tighten the Nishiki Aero II Chain: passo 4, immagine 1 di 1
    • Now that the axle is placed correctly, re-tighten the axle and re-apply the quick-release as shown in Step 1.
Conclusione
Tobias Elder
Membro da: 04/25/13
113 Reputazione
7 Guide realizzate
Cal Poly, Team 21-53, Johann Spring 2013 Membro di Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,441
