Salta al contenuto principale
How to Tie a Tie: Trinity
Cosa ti serve
  1. How to Tie a Tie: Trinity, Preparation: passo 1, immagine 1 di 1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Trinity: passo 2, immagine 1 di 1
    • Wrap the tie around the back of your neck with the wide end on the left side of your body and the narrow end on the right side.
    • The narrow end of the tie will be your active end.
    • Note: The wide end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Trinity, Tying: passo 3, immagine 1 di 1
    • Take the active end and it cross over the wide end, so it is pointing to the left.
    • Note: be sure that the tie always lays flat so that there are no twists in the fabric.
    • Note: Be sure to keep this wrap and all subsequent wraps tight against one another.
  4. How to Tie a Tie: Trinity: passo 4, immagine 1 di 2 How to Tie a Tie: Trinity: passo 4, immagine 2 di 2
    • Wrap active end under the left side and up through the neck loop, so that it points up.
  5. How to Tie a Tie: Trinity: passo 5, immagine 1 di 2 How to Tie a Tie: Trinity: passo 5, immagine 2 di 2
    • Wrap the active end over the left side again, so that it now points down.
  6. How to Tie a Tie: Trinity: passo 6, immagine 1 di 1
    • Wrap the active end under the wide end of the tie, so that it now points towards the right.
  7. How to Tie a Tie: Trinity: passo 7, immagine 1 di 1
    • Wrap the active end over the knot, so that it now points up.
  8. How to Tie a Tie: Trinity: passo 8, immagine 1 di 1
    • Wrap the active end down through the neck loop, and pull to the left side, so that it now points left.
  9. How to Tie a Tie: Trinity: passo 9, immagine 1 di 1
    • Wrap the active end over the wide end of your tie.
    • Note: leave this wrap a little loose as it will be used in step 11.
  10. How to Tie a Tie: Trinity: passo 10, immagine 1 di 1
    • Wrap the active end under the right side and up through the neck loop, so that it points up.
  11. How to Tie a Tie: Trinity: passo 11, immagine 1 di 2 How to Tie a Tie: Trinity: passo 11, immagine 2 di 2
    • Pull the active end down through the wrap you made in step 9 (see picture 2). Then pull the active end so that it points left.
    • Note: leave this new wrap a little loose as it will be used in step 13.
  12. How to Tie a Tie: Trinity: passo 12, immagine 1 di 2 How to Tie a Tie: Trinity: passo 12, immagine 2 di 2
    • Wrap the active end under the wide tie to the right, so that the active end is pointing right.
    • Note: be sure that is tucked completely behind the wide end.
  13. How to Tie a Tie: Trinity: passo 13, immagine 1 di 3 How to Tie a Tie: Trinity: passo 13, immagine 2 di 3 How to Tie a Tie: Trinity: passo 13, immagine 3 di 3
    • Wrap active end over the knot and pull through the diagonal wrap you made in step 11 (see picture 3).
  14. How to Tie a Tie: Trinity, Finishing: passo 14, immagine 1 di 1
    • Tighten the neck knot by holding the knot and pulling on the narrow end of the tie away from you.
  15. How to Tie a Tie: Trinity: passo 15, immagine 1 di 1
    • Tighten the neck loop by pulling down on the wide end of the tie and sliding the knot up toward your neck.
  16. How to Tie a Tie: Trinity: passo 16, immagine 1 di 3 How to Tie a Tie: Trinity: passo 16, immagine 2 di 3 How to Tie a Tie: Trinity: passo 16, immagine 3 di 3
    • Tuck the rest of the narrow end into your collar and fold your collar down.
Conclusione
Congratulations! You've successful tied the Trinity knot!
Altre 3 persone hanno completato questa guida.
The Electric Warthogs Membro di The Electric Warthogs
Community
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 33
Tutti i Tempi: 871
