Salta al contenuto principale
How to Tie a Tie: Four-in-Hand
Cosa ti serve
  1. How to Tie a Tie: Four-in-Hand, Preparation: passo 1, immagine 1 di 1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Four-in-Hand: passo 2, immagine 1 di 1
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: The narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Four-in-Hand, Tying: passo 3, immagine 1 di 1
    • Take the active end and cross it over the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Four-in-Hand: passo 4, immagine 1 di 1
    • Wrap active end under the narrow end, so that it now points to the right.
  5. How to Tie a Tie: Four-in-Hand: passo 5, immagine 1 di 1
    • Wrap active end over the narrow end, so that it now points to the left.
    • Note: leave this wrap a little loose, as it will be used in step 7.
  6. How to Tie a Tie: Four-in-Hand: passo 6, immagine 1 di 1
    • Pull the active end up through the neck loop, so that it now points up.
  7. How to Tie a Tie: Four-in-Hand: passo 7, immagine 1 di 2 How to Tie a Tie: Four-in-Hand: passo 7, immagine 2 di 2
    • Pull the active end down through the wrap you created in step 5 (see second picture).
  8. How to Tie a Tie: Four-in-Hand, Finishing: passo 8, immagine 1 di 1
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  9. How to Tie a Tie: Four-in-Hand: passo 9, immagine 1 di 1
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  10. How to Tie a Tie: Four-in-Hand: passo 10, immagine 1 di 1
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
Conclusione
Congratulations! You've successful tied the Four-in-Hand knot!
Altre 5 persone hanno completato questa guida.
The Electric Warthogs Membro di The Electric Warthogs
Community
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 63
Tutti i Tempi: 2,356
