Salta al contenuto principale
How to Tension the Barreto Trencher E718MTH4S 2016 Chain
Cosa ti serve
  1. How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Engage the hub lock pins: passo 1, immagine 1 di 3 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Engage the hub lock pins: passo 1, immagine 2 di 3 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Engage the hub lock pins: passo 1, immagine 3 di 3
    • Make sure that both ignition switches are turned to the off position. There is one on the engine and one on the control panel.
    • Pull the ring near one of the wheel hubs straight out, away from the wheel.
    • Rotate it so that the small roll pin lines up with its slot.
    • Release the ring so that the lock pin slides into the wheel. You may need to rotate the wheels a little before the lock pin fully engages.
    • With the pin engaged, it should be very hard to turn the wheels.
    • Repeat this step so that the lock pins on both wheels are engaged.
  2. How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Loosen the adjuster screw locknut: passo 2, immagine 1 di 2 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Loosen the adjuster screw locknut: passo 2, immagine 2 di 2
    • Make sure the boom is in a horizontal position.
    • Use a 3/4 inch open-end wrench to loosen the adjuster screw locknut so that you have enough space to tighten the adjuster screw as needed.
  3. How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Adjust the chain tension: passo 3, immagine 1 di 3 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Adjust the chain tension: passo 3, immagine 2 di 3 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Adjust the chain tension: passo 3, immagine 3 di 3
    • Use a 1/2 inch open-end wrench to tighten or loosen the adjuster screw.
    • Adjust the screw until there is about a 1 inch gap (3.8 cm, or about two fingers wide) between the bottom of the boom and the lowest part of the top of the chain.
  4. How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Tighten the adjuster screw locknut: passo 4, immagine 1 di 2 How to Tension the Barreto Trencher E718MTH4S 2016 Chain, Tighten the adjuster screw locknut: passo 4, immagine 2 di 2
    • After the chain is properly tensioned, use a 3/4 inch open-end wrench to tighten the adjuster screw locknut.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Adam O'Camb
Membro da: 04/11/15
197.108 Reputazione
416 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 80
Tutti i Tempi: 3,844
