Salta al contenuto principale
How to Tailor Pants Waistband
Cosa ti serve
  1. How to Tailor Pants Waistband, How to Tailor Pants Waistband: passo 1, immagine 1 di 1
    • Pinch the back of the pants until they fit how you want.
  2. How to Tailor Pants Waistband: passo 2, immagine 1 di 1
    • Mark with fabric chalk on either side of the back seam where the two sides of fabric meet when you pinch the waistband to fit well.
  3. How to Tailor Pants Waistband: passo 3, immagine 1 di 2 How to Tailor Pants Waistband: passo 3, immagine 2 di 2
    • Rip the back seam, waistband, and any belt loops using a seam ripper
    • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury.
    • Keep fingers away from the path of the seam ripper and seam rip away from yourself at all times.
  4. How to Tailor Pants Waistband: passo 4, immagine 1 di 2 How to Tailor Pants Waistband: passo 4, immagine 2 di 2
    • Pinch together where the chalk marks are.
  5. How to Tailor Pants Waistband: passo 5, immagine 1 di 1
    • Pin on the inside of where you are holding the marks together with at least 3⁄8” of space on the open side of the seam ripped area.
  6. How to Tailor Pants Waistband: passo 6, immagine 1 di 2 How to Tailor Pants Waistband: passo 6, immagine 2 di 2
    • Stitch in large basting stitches on the inside of the pants along where you pinned.
    • Basting stitches are long stitches that are easily removable.
  7. How to Tailor Pants Waistband: passo 7, immagine 1 di 1
    • Try on the pants to see if they fit.
    • If they don’t, take out the stitches you made and adjust until they do.
    • If they fit, then you can proceed!
  8. How to Tailor Pants Waistband: passo 8, immagine 1 di 2 How to Tailor Pants Waistband: passo 8, immagine 2 di 2
    • Sew smaller stitches along where your basting stitches were.
    • Take out the pins after you are finished sewing.
  9. How to Tailor Pants Waistband: passo 9, immagine 1 di 1
    • Cut the extra fabric on the inside of the pants while leaving 3/8" of space between the scissors and stitches.
    • If you think you may need to adjust these pants again in the future then you can choose to skip this step.
  10. How to Tailor Pants Waistband: passo 10, immagine 1 di 1
    • Try on your new, well-fitting pants!
Conclusione
If the size needs to be changed at a later time, you can always take out the seams and readjust.
Maya Leonard
Membro da: 11/05/24
181 Reputazione
1 Guida realizzata
UC Davis, Team 1-5, Vidal-Chiesa Fall 2024 Membro di UC Davis, Team 1-5, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S1G5
3 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 248
