Salta al contenuto principale
How to Stabilize the Stem of a Longwise ES06 E-Scooter
Cosa ti serve
  1. How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 1, immagine 1 di 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 1, immagine 2 di 2
    • Power off your E-Scooter and make sure it is not charging.
  2. How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 2, immagine 1 di 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 2, immagine 2 di 2
    • Slide the locking clip out from the base of the stem.
    • Unlock the clamp on the stem.
  3. How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 3, immagine 1 di 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 3, immagine 2 di 2
    • Gently lower the stem onto the back wheel and keep it stable.
  4. How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 4, immagine 1 di 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 4, immagine 2 di 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 4, immagine 3 di 3
    • Using an adjustable wrench, carefully tighten the bolt at the base of the stem.
    • This will make the stem stable.
    • Do not use the wrench on the spring between the stem and the bolt as it may damage the wires beneath.
  5. How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 5, immagine 1 di 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 5, immagine 2 di 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 5, immagine 3 di 3
    • Using a slotted/flathead screwdriver, carefully tighten the screw on the clamp.
    • This will prevent the clamp from popping open.
  6. How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 6, immagine 1 di 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: passo 6, immagine 2 di 2
    • Use a Phillips #0 to tighten the screw on the locking clip.
    • This helps the clamp to stay in place and prevent it from popping open.
Conclusione
Maithili Admane
Membro da: 09/24/22
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 53
Tutti i Tempi: 599
