Salta al contenuto principale
How to Shorten a Sweatshirt Using the Original Hem
Cosa ti serve
  1. How to Shorten a Sweatshirt Using the Original Hem, How to Shorten a Sweatshirt Using the Original Hem: passo 1, immagine 1 di 1
    • Lay your crewneck on a flat surface.
  2. How to Shorten a Sweatshirt Using the Original Hem: passo 2, immagine 1 di 2 How to Shorten a Sweatshirt Using the Original Hem: passo 2, immagine 2 di 2
    • Find your new desired length and mark it with chalk.
    • Using your chalk mark, use a ruler to mark across the width of your crewneck.
  3. How to Shorten a Sweatshirt Using the Original Hem: passo 3, immagine 1 di 1
    • Measure one inch below your desired length and mark using chalk.
  4. How to Shorten a Sweatshirt Using the Original Hem: passo 4, immagine 1 di 2 How to Shorten a Sweatshirt Using the Original Hem: passo 4, immagine 2 di 2
    • Cut along your newly marked line.
    • Make sure to cut one layer at a time to ensure a clean cut.
  5. How to Shorten a Sweatshirt Using the Original Hem: passo 5, immagine 1 di 1
    • Using a ruler, mark 1/2 an inch up from the hem of your crewneck.
  6. How to Shorten a Sweatshirt Using the Original Hem: passo 6, immagine 1 di 1
  7. How to Shorten a Sweatshirt Using the Original Hem: passo 7, immagine 1 di 1
    • Flip the hem inside out and align with the cut edge of your crewneck.
    • Make sure the pieces are "good side" to "good side" by ensuring the seams are facing outward.
  8. How to Shorten a Sweatshirt Using the Original Hem: passo 8, immagine 1 di 1
    • Pin both pieces together with all pins facing perpendicularly to the lines you marked.
  9. How to Shorten a Sweatshirt Using the Original Hem: passo 9, immagine 1 di 2 How to Shorten a Sweatshirt Using the Original Hem: passo 9, immagine 2 di 2
    • Sew one inch away from the edge, removing the pins as you go.
    • This step can also be done by hand with thread and a needle.
  10. How to Shorten a Sweatshirt Using the Original Hem: passo 10, immagine 1 di 2 How to Shorten a Sweatshirt Using the Original Hem: passo 10, immagine 2 di 2
    • Flip the hem right side out and admire your creation!
Linea Traguardo
Izzy DeLaGarza
Membro da: 11/05/24
181 Reputazione
1 Guida realizzata
UC Davis, Team 4-8, Vidal-Chiesa Fall 2024 Membro di UC Davis, Team 4-8, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G8
3 Membri
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 228
Tutti i Tempi: 1,139
