Introduzione
Chainsaws are very useful for cutting; however, their teeth eventually dull and need to be replaced. This guide provides a simple, easy, and reliable method of sharpening chainsaw teeth quickly.
The possibility of being injured in this instruction is very low, as this instruction requires the chainsaw to be OFF. If the chainsaw is on, it is possible to be severely injured, so leave the chainsaw off. If you are worried about being cut by the chainsaw’s teeth, gloves can be worn, but they are not necessary.
Although a Husqvarna chainsaw was specifically used, the details of this instruction will work for all chainsaw types. It may be useful to determine the radius of your chainsaw’s teeth to find a file that fits properly. The Husqvarna has a chain pitch, gap between the teeth, of 3/8”, which is the radius of the file used.
Cosa ti serve
Remove the drill-bit from the drill and insert the file in its place.
Tighten the file in place by spinning the drill's head near the base of the file.
Following these steps will prevent the tediousness of the process, as well as make the process quicker than usual. The chainsaw can be sharpened multiple times before it is required to be replaced.
